WD Cracked
POD
12-10-2004 11:31:07
We have a WD that has a crack in the block between the first and second cylinder. We put the head back on with some extra gasket sealer in that area and started using the tractor again. Do we have a potentual long term problem that needs a permanant fix, or sould we just keep on running?
BushogPapa
12-10-2004 18:00:11
 Re: WD Cracked in reply to POD, 12-10-2004 11:31:07
Probably 85% of the AC blocks of those years have cracks between the lower sleeves... Not a real problem if the oil doesent get too much antifreeze in it... Old-time AC mechanics recommended installing the sleeves, then plastering the lower part of them with the "thick stuff from the bottom a paint can"
!!!!! I had 2 WD-45 blocks re-conditioned, resistance-welded and pinned at "Columbus Col-Weld" in Columbus, Ohio.. They guaranteed them never to crack there again..!! I ALWAYS install AC sleeves with the "O-ring", AND Plenty of non-Hardening aviation gasket sealer from Permatex.. I plaster the entire lower water jacket area with the sealer, to prevent future leaks around the sleeves.. If you want to stop the coolant from getting into the oil from a crack in the lower web between the sleeves.... Remove all the sludge and rust laying in the bottom of the water jacket..Dry it out good, and useing a funnel and hose...pour in a good Pint to a pint and a half of the Permatex Non-hardening sealer in the block, and let it flow over the entire lower surface...it remains flexible and will stop the leak... You can pour it in thru the water pump opening, with the water pump removed--OR remove the thermostat houseing and the rear flat plate between the 2 rear head bolts, and pour it in thru those water jacket openings, useing a funnel and hose... Sure better than a complete tear-down if it doesent need an overhaul.. Cracks at the top of the block should not be a problem--the head gasket should seal that up...
Ron..
Jerry (mo)
12-10-2004 14:34:03
I've been told it is't that big a problem. My wd45 has cracks between all cylinders. The problem with mine is its also cracked on the bottom and I'm getting water in the oil. With cracks on top there is no where for the water to go because of the sleeves and the head gasket should seal the sleeves. Go ahead and keep running her, just check the oil for water before each use. You should always check the oil anyway right :)
