Allis power plant
randy baldauf
12-08-2004 19:36:39
I have a 4 cyl allis power plant that has a 138cid engine. what tractor will that motor fit? Model B? Thanks
steve(ill)
12-09-2004 15:20:47
 Re: Allis power plant in reply to randy baldauf, 12-08-2004 19:36:39
it will fit a B or C, it was original in the D10-12 tractor.
Fruitfarmer
12-09-2004 13:50:17
The power unit will fit an Allis B and give the little booger a lot more oomph! You'll have to use your B's flywheel and clutch. Maybe you'll have to drill out the front mounts on your B to accept the larger studs or bolts in the power unit. Also, the exhaust pipe on the power unit will be more to the left, requiring enlarging the hole in the B's sheet metal. The temperature guage on the B may not transfer to the power unit, requiring installation of a new one to a different location.
