wd45--generator
jerry g
12-08-2004 10:15:09
i have a wd45 that i just bought a reman. generator. my brother says i need to polarize the generator. i've put ones on years ago on other wds and don't remember having to do this? my question is do i need to do this and how do i do it. i have some idea but am not sure
JMS/MN
12-08-2004 10:28:29
 Re: wd45--generator in reply to jerry g, 12-08-2004 10:15:09
I know that there is a formal explanation for your question, but I don't remember it. Has to do with Field terminal, Battery. Generator, etc. Bottoom line is- after everything is hooked up and before you start the engine, turn on the ignition and use a jumper wire across any two terminals that produces a spark when you make momentary contact. That polarizes the generator and tells the electrons which way to go.
steve(ill)
12-08-2004 11:16:25
 Re: wd45--generator in reply to JMS/MN, 12-08-2004 10:28:29
generator A terminal goes to G on regulator. F on generator goes to F on regulator (field= ground), the B on the regulator is battery power from the ampmeter. prior to starting motor, turn on key, and touch B and G terminals together for 1 second to teach the voltage regulator where + is.
