pistons and sleeves
keith giffin
12-08-2004 06:41:05
Will pistons and sleeves for a wd45 work in a wc? I know the diameter will work but what about the wrist pin location? Thanks!
Bill(IN)
12-08-2004 19:34:56
 Re: pistons and sleeves in reply to keith giffin, 12-08-2004 06:41:05
The wrist pin location in the wd45 pistons is 1/4 inch higher than in the wc's to compensate for the 45's 1/2 inch longer stroke. Therefore the 45 piston would be 1/4 inch too low at TDC making your compression ratio very low.
Keith Giffin
12-09-2004 16:29:18
 Re: pistons and sleeves in reply to Bill(IN), 12-08-2004 19:34:56
Thanks for the information.
Keith Giffin
Keith Giffin
12-09-2004 16:28:49
bw in mo
12-08-2004 17:26:48
There are 7 different compression ratios that run from 4.5 : 1 low octane fuel to 7.25 : 1 for gasoline. the latter being for WD 45.
Jim se il
12-08-2004 17:18:18
I think the compression will be too low
steve(ill)
12-08-2004 19:12:23
 Re: pistons and sleeves in reply to Jim se il, 12-08-2004 17:18:18
i believe if you keep the rods with the pistons they came with, you can change between blocks and not ahve to worry about the "height".
Jim se il
12-08-2004 20:20:10
 Re: pistons and sleeves in reply to steve(ill), 12-08-2004 19:12:23
a parts book list the rods as the same (not a-c book)
