WD 45 FUEL QUESTION
jiminoystercreek
12-07-2004 17:24:29
Just finished a 1250-mile trip picking up a 57 WD45 I just bought from a fella. I have never owned one of these before and have a question on the radiator louver adjustment. The decal says to set the louvers at 170 degrees on regular gas and to set them at 190 degrees on tractor gas. What is tractor gas?
I've got a operator's and service manual on the way, but in the meantime, I'm runnin on pure instinct here. Thanks
Bill(Wis)
12-13-2004 17:28:29
 Re: WD 45 FUEL QUESTION in reply to jiminoystercreek, 12-07-2004 17:24:29
AC made a WD45 equipped to burn distillate fuel (also called tractor fuel) and it was tested at Nebraska in Oct,1953. (#511) Tractor had to be equipped with certain items to burn distillate, among them, a modified manifold usually marked with a "K", carbureter changes, colder spark plugs, and run the temps higher by using shutters on radiator as well as thermostat. All of this info will be found in the appropriate manuals.
JMS/MN
12-08-2004 10:31:49
Someone will correct me if I'm wrong, but I've never heard of a WD45 with the radiator louver. Only on WD tractors, some WC, etc.?
farmweld
12-10-2004 11:24:29
 Re: WD 45 FUEL QUESTION in reply to JMS/MN, 12-08-2004 10:31:49
never heard of this in my grandpa's WD. possible though
BushogPapa
12-07-2004 23:07:13
I believe the "Tractor Gas" mentioned is Kerosene...only to be used in "All-Fuel" engines.....
Ron..
