WD 45 starting problem
s.i. tractor
12-06-2004 04:24:48
When I try to start the tractor there is get no response at all. The starter does not turn over or even click. The battery is strong. Any suggestions as to where to start troubleshooting?
Billy johnson
12-06-2004 19:03:56
 Re: WD 45 starting problem in reply to s.i. tractor, 12-06-2004 04:24:48
It could be the starter button not making contact, had one on an AC G that done it to me. had to use pliers to pry the leaver more to get contact.
Eldon (WA)
12-06-2004 08:12:35
I just had the same problem. I found that a brush was hung up in the starter.....then found that the brushes were worn and needed replacing.
Gene[IN]
12-06-2004 08:01:54
sounds like you lost ground at starter. remove starter and clean the rust off it.
John Cunningham
12-10-2004 01:53:56
 Re: WD 45 starting problem in reply to Gene[IN], 12-06-2004 08:01:54
If the above does not work the contact in your switch is bad. Use one side of a jumper cable to go across the terminals. Be careful make sure the tractor is out of gear. My dad used to use a bare plyers across for testing.
