1955 WD45 pto (gasket or shim?)
winton-mississippi
11-28-2004 17:07:14
My WD45 was leaking where the stub shaft rear bearing case meets the pto housing.I removed the bearing case and the adjoining round metal shim. The parts manual gives 3 options-2 different thickness metal shims or a paper gasket?? Which one should I use?? Parts #'s are 224655 (.005 paper gasket) #224656 (.005 steel shim) and #224657 (.010 steel shim).
wdTom
11-29-2004 17:47:06
 Re: 1955 WD45 pto (gasket or shim?) in reply to winton-mississippi, 11-28-2004 17:07:14
You can use different thickness paper, gasket material, shims stock (beer can cut open) or whatever to get the adjustment described. It can take a few tries, don't rush it or do it when in a hurry.
Dale(MS)
11-29-2004 04:23:29
Winton, I would think they wanted a free rolling fit with no end play. Vary the shims and gaskets until there is no binding and no end play. Not sure in this particular case but thats the way alot of AC's bearings are adjusted. Dale
