WD45 Rocker Arm to Valve Cover sequence
wet in NY
11-28-2004 15:18:09
After 2 years, I am in the process of putting the value cover on. Unfortuantely, I can't remember what was there.
After the rocker arm, does the rubber washer go on? Or after the splash guard.
Then does the splash guard have nuts on it?
Thanks!
COLIN MCAFEE
12-01-2004 18:28:37
 Re: WD45 Rocker Arm to Valve Cover sequence in reply to wet in NY, 11-28-2004 15:18:09
FIRST GOES THE ROCKER ARM ASSEMBLY, THEN THE SPLASH GUARD, THEN THE FIRST SET OF NUTS. NEXT GOES THE COVER, RUBBER WASHER, METAL WASHER, THEN THE LAST SET OF NUTS.
I ADDED HARDENED WASHERS UNDER BETWEEN THE FIRST SET OF NUTS AND THE SPLACH GUARD; KEEPS THE TORGUE OF THE NUTS FRON CHEWING ON THE SPLASH GUARD.
