WICO Magneto
Dean
11-27-2004 07:07:40
I have a new looking WICO model X, No. Y-54, Spec. XH-1343 magneto in a Fairbanks-Morse box labeled FM-ZV4B7, Wisconsin Motor Corp., VE4 and VF4. The magneto is for a 4 cylinder application. Clearly the box is incorrect but, perhaps, someone swapped a FM for a WICO on a Wisconsin engine years ago. Does anyone know if this magneto fits a Wisconsin V4 or, if not, what it does fit? Also would like to know what it is worth. Mag is complete with impulse coupling and works fine.
Dean
Rod (NH)
11-27-2004 16:10:28
 Re: WICO Magneto in reply to Dean, 11-27-2004 07:07:40
Hi Dean,
According to my Wisconsin parts manual for the VE4 and VF4 engines, both the Fairbanks-Morse FM-ZV4B7 (standard) and the WICO XH-1343B (optional) were used on those engines. The parts book lists the Wisconsin numbers as Y-106 for the F-M and Y-54 for the WICO. They would appear to be completely interchangeable.
third party image Rod
Dean
11-27-2004 16:21:06
 Re: WICO Magneto in reply to Rod (NH), 11-27-2004 16:10:28
Thanks, Rod. Seems reasonable as my uncle had this mag in the (wrong) FM box. He never had a Wisconsin V4 engine and probably picked the mag up at a sale. Interesting man: Never married and made his living on 70 acres unitl he died in 1986. Raised tobacco, cattle, both milk and beef, and hay. Big tractor: F-30. Second tractor: Farmall Regular bought new in 1927.
Dean
Steve in N.J.
11-27-2004 15:49:40
Dean,
We do a lot of mag work. Some of the "XH" series Wico mags will work in place of say a Fairbanks FMJ4B3 mag. Depending on the weight of the Wico unit, also will tell you if it's a real mag equipped with a magnetic rotor assy which produces the power, or one that has advance wieghts in it and needs to be powered up like a distributor. The lightwieght is the distributor style unit. HTH.
Steve/B&B Custom Circuits
old
11-27-2004 08:42:52
You might be able to get some info on that mag at. magneeders.com
Dean
11-27-2004 11:24:56
 Re: WICO Magneto in reply to old, 11-27-2004 08:42:52
Thanks for the link. I will check it out.
Dean
