D17 wont idle
Joe B
11-27-2004 04:58:51
I just replaced the govoner gear and weights that blew apart in my D17 and now it constantly runs at about 3/4 throttle.The only way i can get it to idle is if i manually grab the carb linkage and pull it back. I took the govoner out again and everything looks fine but the hand control has absolutly no effect on the engine speed.Any ideas or suggestions?Thanks
Sid
11-28-2004 13:09:50
 Re: D17 wont idle in reply to Joe B, 11-27-2004 04:58:51
You might have a spring missing that holds the carb linkage back.
Tom in Michigan
11-28-2004 05:59:40
Joe, Have you tried adjusting the linkage from the throttle lever to the governor? There is a baseline adjustment (in the manual if you have one) that will be a starting point and you can fine-adjust from there. Tom
