Steering wheel removalon C
The Big C
11-23-2004 17:24:54
Just looking for some info on removal of steering wheel on a model C. Tried it with a wheel puller but it kept slipping off and not releasing. Any info appreciated.
Dick L
11-24-2004 07:52:32
 Re: Steering wheel removalon C in reply to The Big C, 11-23-2004 17:24:54
RED HOT is the two word KEY. Red hot won"t hurt it a bit and then it does not take a very big hammer. I use a foot long steel bar placed on the botton of the hub an give it a whack with a two pound hammer. It is tapered and the hub expands when hot, then ya have the rusty half moon key in the shaft that hangs up a little.
Rod (NH)
11-23-2004 17:42:39
Heat and a hammer. You could even put some initial strain on it with a puller at the same time. That's what I did on my B.
Dana (Iowa)
11-24-2004 05:19:44
 Re: Steering wheel removalon C in reply to Rod (NH), 11-23-2004 17:42:39
I had the same problem. Gear puller, some heat and a few choice words solved the problem!!
Tom(ID)
11-24-2004 07:15:13
 Re: Steering wheel removalon C in reply to Dana (Iowa), 11-24-2004 05:19:44
I had a B but it was the same problem. I used a puller (which liked to come off), lots of Kroil and a hammer. I would check it before work and after and eventually the thing came loose. I tightened the puller a bit every so often.
