WD-45 and Stuck Hydraulic Rear Lift
Mark in MN
11-22-2004 19:33:45
The rear hydraulic lift on my 50's WD-45 is stuck in the up position. I can move the lift lever on the steering column to the down position, but the lift arms will not go down. I think I can actually hear the tractor laboring to continue lifting even though I am trying to lower the lift arms. Can someone please tell me what is broke and how to fix this problem. I checked the hydrualic fluid and it is full. Thanks much for the help.
another Mark in MN
08-23-2006 06:00:12
 Re: WD-45 and Stuck Hydraulic Rear Lift in reply to Mark in MN, 11-22-2004 19:33:45
I have the same problem - rams stuck in extended position: tractor laboring (and hydro line leaks) any time clutch is out. Dash lever moves fine with no binding. Is there additional linkage concealed somewhere? I hate to start experimenting with pump control settings if the problem is more mechanical. What was your solution?
Sid
11-23-2004 05:24:56
I agree it sound like the linkage problem. It is not like the D series tractors pump and linkage are external. My first guess is the traction booster linkage. At least that is what the problem when my tractor was doing that.
Don Dittmar
11-23-2004 04:33:02
Sounds to me like there is a problem with either the linklage or the valve. If it is like the D series, you can pull the pan off the bottom of the torque tube and look in there and see if your linkage has maybe come off. The valve is made part of the pump, but is serviceable. In either case you need to pull that pan and figure out what is going on
Terry(GA)
11-23-2004 09:46:27
 Re: WD-45 and Stuck Hydraulic Rear Lift in reply to Don Dittmar, 11-23-2004 04:33:02
Disconnect the linkage rod going to the pump lever and move the pump lever with your hand.Moving it down should release the pressure.I have had the same problem with mine.
TerrySD
11-23-2004 17:16:36
 Re: WD-45 and Stuck Hydraulic Rear Lift in reply to Terry(GA), 11-23-2004 09:46:27
I had the same problem. It was a broken pin inside the pump. If I remember right I could lower the arms by screwing the screw at the front of the pump all the way out(screw D).
