WD-45 belt-pully cover plate
Percy
11-22-2004 17:29:28
I have a WD-45 and would like to take the belt-pully off. We had a WD-45 Desel in the early 60s and I seem to remember that was a tin cover that went in the hole when you took the pully off. If my memory is correct it looked like the lid of an old axle greese can. Anyway I would like to find one. Thanks for any help.
Tim in NY
11-24-2004 14:05:38
 Re: WD-45 belt-pully cover plate in reply to Percy, 11-22-2004 17:29:28
I have a Belt Pulley Plug for a WD/WD45 that I'll sell. Email me if interested. Thanks,Tim
DanD.
11-24-2004 13:41:30
They show up on ebay every once in a while for not much money.
DanD.
11-24-2004 13:43:44
 Re: WD-45 belt-pully cover plate in reply to DanD., 11-24-2004 13:41:30
In fact, here's one, now.
wdTom
11-23-2004 18:47:14
My brother found that a PVC pipe clean out cover would fit perfectly. It is maybe for 3" pipe and has an O ring I think and it has been inhis WC for years now. 45 would be the same. Check with hardware or plumber. Think they are used where you have a tee in a drain line and want a quick and easy access for cleanout. I found a square O ring stock in McMaster that is the perfect size for a seal on the AC metal cap you describe. I put the carefully cut seam at the top and it has been good so far, although I haven't run the tractor that much since.
