slow down WD45 in reverse for snow blowing?
Gary r. voigt
11-20-2004 18:14:59
Hello, i"am trying to slow down my WD45 in reverse when blowing snow. my setup is a 7" mckee bros. out of canada and i"am going way too fast in reverse. when the deep snow comes i will be in trouble because all i can do is slip the oil clutch...is this a bad idea. also my tires are way too big i think than what was standard. i think i"am going to find a 544 gas international with a cab so my WD45 may be for sale.
thanks, Gary r. voigt
JMS/MN
11-21-2004 14:39:13
 Re: slow down WD45 in reverse for snow blowing? in reply to Gary r. voigt, 11-20-2004 18:14:59
The clutch is made to be used for that purpose. You can also slow down the ground speed by getting some combine tires and rims- 26 inch rims with the same bolt pattern as the rear wheel. Check from a 55 JD, older Gleaners, etc. with the eight bolt pattern.
