WD45 clutch question
Ken C
11-20-2004 09:12:11
The release lever springs (I'm on page 50 of the I&T Manual) have been breaking, and I am down to just one, & the clutch seems to release as it always has, just fine. How bad is this, & can they be replaced without splitting the tractor? It's a 1954 WD45. Thanks!
Ken C
Texas Denny
11-21-2004 06:35:53
 Re: WD45 clutch question in reply to Ken C, 11-20-2004 09:12:11
I have now re-read your question for the third time. The first time I read it yesterday. And still, I do not understand. I assume you are talking about the foot clutch (though you don't say). The foot clutch has three types of springs. One is the return spring that pulls the fork back off of the throw out bearing. The second is on the pressure plate that squeezes the clutch disk. The third is the shock springs on the clutch disk. I don't know how you could tell the shock springs are broken - don't think they can be seen without disassembly. The way you write the question, it sounds like the spring you are talking about is one that has at least three alike. This would mean either the disk or the pressure plate. I've never known anyone to replace a clutch disk shock spring. Or to do the ones on the pressure plate (though I have disassembled them for cleaning). These cannot be removed without pulling the engine. You don't need to split a 45 to remove the engine because it has side frames. I don't have your version of the IT manual so don't know what is on page 50. More info would help.
Texas Denny
11-21-2004 07:01:15
 Re: WD45 clutch question in reply to Texas Denny, 11-21-2004 06:35:53
I just read a similar question on the stratton board. If one spring will return the clutch pedal, you are good to go. If you can pull the pedal back toward the rear axel after letting it out, the throw out bearing may be riding on the pressure plate fingers. This could wear out the fingers, the throw out bearing and the fork. I guess there is an inspection plate under the starter. I've never replaced one through that hole but the hole must be there for a reason - maybe to replace those springs. I think you could survive a while with an exterior spring if the throwout bearing is pulled away from the pressure plate.
Ken C
11-21-2004 10:23:22
 Re: WD45 clutch question in reply to Texas Denny, 11-21-2004 07:01:15
I noticed the broken springs when I was greasing the clutch release bearing under the tractor. You have to remove the two thumb screws & then remove the small plate. The pieces were laying inside. You can easily see the levers & springs of which there are six. Five of my springs are gone & only one left. The clutch & clutch pedal work fine. I hope this helps. What is the Stratton board?
Thanks, Ken C
Texas Denny
11-21-2004 13:27:52
 Re: WD45 clutch question in reply to Ken C, 11-21-2004 10:23:22
Well this sure sounds like the springs on the pressure plate. If you have one left, I would expect lots of clutch slipping. And you are correct. If springs break on the pressure plate, you'll need to pull the engine.
Texas Denny
11-21-2004 06:53:47
Just read a similar question from a different person on the unofficial ac site. This fellow says there are two clutch return springs for the throw bearing. Guess I don't remember that in spite of having pulled 5 of these engines. If you have got one spring and you still have free play on the clutch, you should be fine. If the pedal won't return all the way and the fork rides on the throw out bearing, this could wear out the throw out bearing or the fork. I can't visualize a way to replace these springs without pulling the engine.
