WD45 Steering wheel? Quadrant replacement problem
WD45 guy
11-17-2004 08:09:49
I have a quadrant to replace a broken one. I have drilled out the pins on the steering wheel and can't budge it. Any tricks or ideas that can help? I would really appreciate it!
wdTom
11-17-2004 17:19:19
 Re: WD45 Steering wheel? Quadrant replacement pro in reply to WD45 guy, 11-17-2004 08:09:49
After you get the puller on and tight if it doesn't come off try a little heat on the hub of the steering wheel. Keep shaft cool with cold wet rag.
Gatz
11-17-2004 08:27:20
Soak with a good penetrating oil for a day or two (if time allows).
Make a small dent in the center of the shaft with good center punch, then use a heavy-duty 3-prong wheel/gear puller.
Don't pound on the shaft; it will only enlarge the end.
Those old steering wheels must've been shrunk-fit onto the shaft.
WD45 guy
11-17-2004 11:07:53
 Re: WD45 Steering wheel? Quadrant replacement pro in reply to Gatz, 11-17-2004 08:27:20
Great, I'll give that a shot. Yeah, it is really on there tight.
50wd
11-17-2004 16:16:35
 Re: WD45 Steering wheel? Quadrant replacement pro in reply to WD45 guy, 11-17-2004 11:07:53
Why not just remove the pin from the lower end and pull the wheel and shaft out? The U joint usually comes loose without too much problem.
WD45 guy
11-18-2004 08:58:33
 Re: WD45 Steering wheel? Quadrant replacement pro in reply to 50wd, 11-17-2004 16:16:35
That would have been too easy! I did get the steering wheel off last night. It took about an hour and some persuasion with a gear puller. I couldn't believe the pressure it took to remove it.
Thanks to all that have posted their suggestions!
