ca hydraulic pump
gortx
11-16-2004 07:02:57
I have replaced everything that is replaceable in my CA hydraulic pump and it still will not pump, any suggestions.
Dansen in Ohio
11-17-2004 05:03:16
 Re: ca hydraulic pump in reply to gortx, 11-16-2004 07:02:57
gortx, you did not mention if you are new to CAs or not. Sometimes people working with CAs for the first time do not realize that the pto must be engaged for the pump to run.
Dick L Just Asking
11-17-2004 14:08:08
 Re: ca hydraulic pump in reply to Dansen in Ohio, 11-17-2004 05:03:16
Have you primed the system?
gortx
11-17-2004 06:33:57
Yes I have PTO running, I have removed all check balls and cleaned, replaced, piston springs, unloader valve, all "o" rings, flushed case and filled with proper sae 20 wt. tractor fluid per spec.
pat s
11-17-2004 14:07:32
 Re: ca hydraulic pump in reply to gortx, 11-17-2004 06:33:57
I finally got the pump to pump but, the lift will not go down now.
