Allis B questions
Jeff Alexander
11-15-2004 03:55:16
Just got my first Allis and I love it.
It's a 1950 B I got at an auction and I've cleaned it, tuned it, re-wired it, new seat, etc.
Two questions:
1. It runs great but seems alittle "barky"...you know, louder than other engines that size. And as soon as the throttle is up one notch, it seems to jump from idle to half throttle. Govenor issue or timing issue, or both?
2. Does a 1950 B get decals with the dropped letters or all the same size?
Thanks in advance for any help.
Jeff
Dick L
11-15-2004 06:33:13
 Re: Allis B questions in reply to Jeff Alexander, 11-15-2004 03:55:16
I have had that happen after changing carbs. Something slightly different in the arm that opens and closes the butterfly. The easyest way I have found to correct this it to bend the crossover arm slightly and it doesn"t take much. It is a cut and try thing. To do this I place a 12" cresant on the governer side and place a 1/2" pipe on the carb side and hold both at the same time and push or pull or what ever it takes.
Jeff Alexander
11-15-2004 14:37:01
 Re: Allis B questions in reply to Dick L, 11-15-2004 06:33:13
Thanks Dick, I'll check it out...
