WD-45 PTO LEAK
RAY-MINNESOTA
11-14-2004 19:52:03
PTO IS LEAKING WHERE THE STUB SHAFT BEARING CAGE MEETS THE PTO HOUSING. THE PARTS MANUAL HAS 3 OPTIONS.
1. .006" PAPER SHIM
2. .005" STEEL SHIM
3. .010" STEEL SHIM
HOW DO I KNOW WHICH SHIM TO USE?? TRACTOR SERIAL NUMBER IS 195594. THANKS.
wdTom
11-15-2004 18:14:00
 Re: WD-45 PTO LEAK in reply to RAY-MINNESOTA, 11-14-2004 19:52:03
When I set mine up I used a lot finer adjustment thatn 5, 6, and .010" shims. Think paper, gasket material, beer can, shim stock, etc. It takes a few tries to get it free spinning with no play. A LITTLE pre-loak is OK, but you don't want much.
guyzoo
11-15-2004 15:19:46
put enouph shims to let your shaft turn freely but there is not suppose to have a slack
