wd external hydrolics
shawn van horn
11-14-2004 16:28:25
I am looking to put external hydrolics on my wd and wd 45 the 3 point valve has 2 fittings and a plug. Any ideas? All they will be doing is opening a ram dump gate on a manure spreader and the lift on my chissel
Dave Grubb
11-15-2004 10:12:21
 Re: wd external hydrolics in reply to shawn van horn, 11-14-2004 16:28:25
Be careful of the psi rating on the cylinders and hoses you will be using. The WD45 system is around 3500 psi.
JMS/MN
11-14-2004 17:36:48
The plug you mention is meant to be used as a source of hydraulic power for a remote ram. All three - the plug and two hoses to the lift arms- are in a common chamber, and pressurized at the same time. When the lift arms reach their upper limit of travel, the remote cylinder will be activated.
