tractor decals
dale nurnberg
11-14-2004 14:11:08
I have a WD45, I would like to find some pictures of where to place the decals. I got the decals but no pictures as to where they go.
thank you
Scott-IA
11-15-2004 21:24:55
 Re: tractor decals in reply to dale nurnberg, 11-14-2004 14:11:08
Just what decals are you placing? AC, wd45, and air cleaner are prety evident. Some of the rest can be tricky.
block drain is above the block drain to keep antifreeze off when drained.
Wiring schematic can go inside top of the bat box, or on outside on the side.
Hydrolic setting is centered on right side of bat box
Power crater engine is on left side of block just in front of tranny, and just above the oil pan.
oil filter decal goes on filter, as does the "change every 100 hrs"...this goes on the top of filter, but I put mine on the block.
Grease universal joint goes on the steering colum near the frame, and showing when steering is straght.
Snap coupler decal goes on left side of the bell
Keep shields in place is centered above the lift arm on the pumpkin cover, but since it's round, I put mine on the pto shield right behind the pumkin cover.
two warnings about tires goes on the rear rims just inside the valve stem.
Decal about the lever being in down possition goes below the lift controll.
The fill battery decal goes on the top of the box, centered in the rear half of the lid readable from the left of the tractor..... I think.
Did I miss any?
Jeff Alexander
11-15-2004 03:58:56
Go to www.google.com, enter "allis chalmers wd45" into the search window, hit enter, then click on the "images" button in the search results. You will have a virtual plethera of photos of WD45's to look at and print out.
