AC190XT Gas
Jerry Van Horn
11-13-2004 17:07:51
Power steering quit working. Do the power steering and transmission share the same fluid? I noticed moisture in trans fluid.
Joe(TX)
11-14-2004 17:49:10
 Re: AC190XT Gas in reply to Jerry Van Horn, 11-13-2004 17:07:51
The power steering uses the same fluid as the 3 point and remote system. Check to make sure the clanps on the tube from the sump to the hydraulic pump are tight. It's a good chance that the hydraulic pump is worn, at least the section that does the power steering. They used both a 2 and a 3 section pump on this tractor. I had the same problem with my 190XT. Sometimes you can work the steering wheel back an forth and get it to work. If the steering doesn't work, then the power director won't work. they use the same pump section.
