WD45 Crank is Out of the tractor, Is there Any thi
Punchie
11-13-2004 03:27:05
Hi Forum
WD45 Crank is Out of the tractor, Is there Any thing Else I should DO While She is apart?
1954 wd45 Mains where lose. Not spun but look like acid was on them?? Ran fine but was noisy. Oil presser normal. Compession aver. around 115 psi. .
Best place to get a crank and bearings?
Is there anything else I should do before I put her back together? Any seals or etc. ?
Any tips on placing bearings and plastic gauge them?
Thanks!!
Teddy
wdTom
11-13-2004 19:44:10
 Re: WD45 Crank is Out of the tractor, Is there Any in reply to Punchie, 11-13-2004 03:27:05
I don't believe any 45 cranks were shimmed. As far as I know all were sized to fit as is and not designed to be shimmed. If new bearings are loose when the cap is tightened you need to have it line bored or the rod big ind resized. And as was siad, check fit with plasti gauge.
JMS/MN
11-13-2004 16:47:41
Mike the crank to check size. Like Jim D. says, you can get 10-20 thous undersize bearings. Check with various suppliers- I think you might find someone with 25-30 thou undersize- just make sure you get an accurate measurement before you toss the crank. Some parts suppliers also do machine work, so one trip can provide the info you need. Use plastigauge when doing the inserts and mains. Redo it if not within specs the first time. Plastigauge is cheap insurance- follow the directions on the package. Years ago we didn't have even a torque wrench, and overhauls 'worked', but now they are more dependable with good tools.
steve(ill)
11-13-2004 05:59:57
why do you want a new crank and bearings? you say it looks like acid attack, but is it deepor just surface stuff. I would always put new piston rings, hone the cylinders, put new seal on the cylinder liners, and buy a gasket set. I would consider reusing the crank and possibly just reshimming the bearings if they look decent.
Punchie
11-13-2004 07:59:53
 Re: WD45 Crank is Out of the tractor, Is there Any in reply to steve(ill), 11-13-2004 05:59:57
hi steve
Acid burn is what I'm calling it is about 10-13 thousands deep. Mains were loose and shimmed before.
Head was to have been redone a few years back. Was not going to take head off. But may have to if the rods are not right.
Thanks!! Teddy
Jim Danforth
11-13-2004 08:09:07
 Re: WD45 Crank is Out of the tractor, Is there Any in reply to Punchie, 11-13-2004 07:59:53
You could easily have 10-20 thousands machined off to get a perfect crank again. Bearings, O rings, and gaskets are all easily available. Since Kim owns this website, and runs the forum to sell her parts, you should check her supply on those items. If the sleeves are good I wouldn't replace them, just clean them up.
There are a few parts she cannot get, so you can email me for what she doesn't supply.
JImD
Kim
11-13-2004 08:31:47
 Re: WD45 Crank is Out of the tractor, Is there Any in reply to Jim Danforth, 11-13-2004 08:09:07
Since you're passing out info about the site, here's a direct link:
Allis Chalmers WD-45
There are many more parts available plus a fully staffed parts department - you can call with any of your parts needs or questions M-F and they'll be glad to help. Thanks for supporting this site!
