D 17 govonor repair
Joe B
11-10-2004 12:21:14
Can anyone tell me how complicated the removal and repair is for the govonor on my D17?Are rebuilt units available?The problem is that the govonor is stuck wide open-like maybe one of the springs inside broke????Any advice or info would be appreciated.
Doug in IL
11-11-2004 05:47:21
 Re: D 17 govonor repair in reply to Joe B, 11-10-2004 12:21:14
I recently rebuilt mine. It was fairly simple. There are very few parts to it. On mine the holes in the weights were worn egg shaped. Also the weight pins were worn where they went through the weights. I got the parts from Agco. There is a spring in there also. The springs are color coded. Mine was white. I marked the position of the distributor rotor before I took anything apart. I can"t for the life of me remember if I had to remove the distributor or not. Maybe someone else can tell us.
John (MO)
11-10-2004 14:04:41
If it is anything like the govenor on a D-19 it's not really very complicated at all. On a D-19, there are no internal springs, and I would check all the linkage out side the governor first for your problem. I would imagine all parts are available through AGCO although maybe expensive. For my D-19, new weights were about $80 each, not for the pair. I bought used and got all internal parts for under $200. Mine was worn so bad it was cutting into the case.
