no oil pressure
jared(ct)
11-08-2004 13:39:36
my b has absolutly no oil pressure after i rebuilt the engine, the oil is the right weight, the guage is new, and iv tried to prime it a couple times but nothing changed. any ideas?
jared(ct)
11-10-2004 13:42:29
 Re: no oil pressure in reply to jared(ct), 11-08-2004 13:39:36
i got it working now, primed with heavier oil and tihghed up the intake tube, went right up to about 14 psi and a little higher a few minutes later.
Scott-IA
11-10-2004 07:03:28
You may want to check your filter too. Some recently changed their design, and just dropped the bottom out of Allis's oil pressure. I think it was Wix that changed the filter design, who also makes filters for Napa, and maby some others too. Others will be able to expand on this more than me though.
Buster
11-09-2004 16:35:02
I rebuilt mine 10 years ago. It also had a new guage. The indicated oil pressure is little to none. The dealer where I bought my parts said this was common & don't worry about it. It's still running strong so, in my case, he must have been right.
Butch(OH)
11-08-2004 14:43:31
Here is a few things to try or check. Did you install the spring and plug in the end of the cam when you reassembled? Did you forget to install or tighen the oil suction pipe that goes from the block into the oil in the pan? Before you tear into it to check those things remove the oil filter and check to see if the standpipe is still in the middle of the filter base, no pipe, no pressure to gauge. If you have a NAPA or Wix filter pitch it and install a Fram, ACCO or Fleetgaurd. Prime the pump by disconnecting the filter line at the tee fitting just above the bellhousing and pump oil in with a pumper can, 80-90 will assure priming in worn out pumps but it can be done with regular wt motor oil with a good pump. If still no pressure readings remove the filter and start, check for oil coming from the filter tube.
Rya
11-10-2004 06:17:27
 Re: no oil pressure in reply to Butch(OH), 11-08-2004 14:43:31
I am curious why you say to pitch the NAPA or Wix filter?
Ryan
steve(ill)
11-10-2004 06:32:37
 Re: no oil pressure in reply to Rya, 11-10-2004 06:17:27
the ALLIS system works as a bypass filter. the filter is to clean 15% of the oil output from the pump and dump it to sump. you only get the other 85% to make pressusre. THe filters are supposed to be restrictive and keep too much from going easily thru it to sump. Good filters are packed densly with a cotton material. "bad" filters are light material or paper and look more like a automotive filter on the end. WIX is good for a car, but bad on an ALLIS. Use FRAM or BALDWIN.
Allyn in OK
11-09-2004 14:23:16
Mine did the same thing. I knew it was pumping some because the filter had oil in it. A PSI gauge showed it had 5 at full throttle. Capping the filter standpipe had no effect. After splitting the tractor and changing the oil pump it has 10. The AC gauge indicates in the normal range now. I think the first pump had a stuck vane.
steve(ill)
11-08-2004 15:06:15
also take valve cover off and see if there is oil to the top end. if not, prime pump as mentioned and look inside filter.
