allis c grease seals
jk
11-06-2004 17:29:34
i have to put new grease seals in my C, in the spindles for the wheels bearing. is it a hard job to do? i'm planing on re-pacing the bearings unless there shot then i'll replace them. i think the bearings are too tight cuz the wheels hardly spin with the fron off the ground.
steve(ill)
11-07-2004 05:52:10
 Re: allis c grease seals in reply to jk, 11-06-2004 17:29:34
it is an easy job. the original seal were leather, i would get a rubber set to install. the bearings might be o.k., just soak in solvent to clean. there is a 2 or 2.5 inch threaded hex cap on the outside of the axle shaft. unthread it, then take out the cotter pin and unscrew the alxe nut. whole thing just slides off. just like a old car or trailer.
jk
11-13-2004 11:17:34
 Re: allis c grease seals in reply to steve(ill), 11-07-2004 05:52:10
cool, sounds easy enough, thats for the help.
