WC Timeing Gears
shaun
11-06-2004 04:55:10
hey everyone, just wondering what to set the timeing gears to and what degree 180? im new at this and never got to the timeing gears.thanks for your help.
- shaun
Gene
11-06-2004 22:53:53
 Re: WC Timeing Gears in reply to shaun, 11-06-2004 04:55:10
First thing. If you haven't purchased the shop manual for the tractor you should do so. The shop manual has a sketch on how the gears line up. And more importantly where the indicating marks are in relationship with the shaft key ways. Sometimes on previously rebuilt engines you will find additional marks on the timing gears and you keed to know which set of marks to use.
If you don't want to spend the $30- for the shop manual, the reference section in your local library should have a book or two and Allis Chalmers motors. If you are lucky they may even have one of the old Chiltons or Haynes covering the engine.
Here goes. The camshaft gear should have two sets of marks - they may be identical or they may be two different marks - a punch prick and a scribe line - sometimes one punch prick and two punch pricks. The mark opposite - to the right of the key way should be meshed to the same mark on the crankshaft gear. The remaining mark needs to mesh with the same mark on the govenor drive gear.
