AC 170 oils
jrlii
11-03-2004 20:40:27
I just got a 1967 model 170 and reading the manual it calls for "Allis-Chalmers Special Gear Lube" for the transmission/differential/final drive and "Allis-Chalmers Hydraulic Power Fluid 322" or "ATF type A suffix A" for the hydraulic oil.
Any notion what these are in today's nomenclature?
Great tractor. Only managed to bog it down once so far when I drove my 7' Bush Hog into a tall stand of sumac, and is surprizingly stable in cross slope situations. . . Maybe that has something to do with the loaded tires. . .
DanD.
11-06-2004 09:23:10
 Re: AC 170 oils in reply to jrlii, 11-03-2004 20:40:27
The AGCO power fluid 821 XL would be used in all of those applications. Most farm supply stores and even Wal Mart have universal trans-hydraulic oil that can be used in all applications. Check the hydraulic oil in your tractor. If it's red, you would probably want to drain it out before adding any or else get Dexron III/Mercon automatic transmission oil for the application that calls for type A oil.
