Allis Chalmers B ?
Kyle 23
11-03-2004 15:56:24
I want to put a tricycle front end on my Allis Chalmers B will the tricycle front end of a C fit without alot of modifications. If so does anybody have a tricycle front end for sale. Thanks for any help
zb
11-04-2004 10:45:56
 Re: Allis Chalmers B ? in reply to Kyle 23, 11-03-2004 15:56:24
too narrow of tractor for tricycle, knew a guy that did it and almost got killed by it. if you want a narrow front buy a "c" they were built wider for it.
Dick L
11-04-2004 07:09:50
 Here's Some Pictures Of Mine in reply to Kyle 23, 11-03-2004 15:56:24
I like it and it is fun. I use it in pulling contests and have used out in the field to pull a spring tooth drag for fun.
Dick L
11-04-2004 07:11:34
 Well It Was Spose Ta Be in reply to Dick L, 11-04-2004 07:09:50
Forgot to enter the link.
steve(ill)
11-03-2004 19:30:36
i agree with Jim, dont do that to the B. to answer you question, yes, the front end and mount will go right on the B off the C as the motor is the same. you will need to cutout a section of the radiator wraparound at the bottom for the steering arm to stick out. the B steering box runs backward from the C. the C has the arm sticking straight up toward the gas tank. The B would have to still point down so it would turn the right direction. you would need to make a special link from the steering arm on the gear box to the arm on the front end. the B or C would not fit exactly.
Jim Danforth
11-03-2004 18:49:36
You can do it, but why? Typically a C will be worth $200-300 less than a comparable B. The only difference is the narrow front, and the wider rear end. I would be paranoid with the B's narrow back, and a narrow front.
JImD
