FMJ Magneto
Jiver
11-03-2004 10:49:48
I am rebuilding a Fairbanks FMJ4B3 magneto. How can you tell if the magnets should be remagnetized?
Can the rotor shaft be removed without losing magnetism?
Where can it be sent to be remagnetized?
Thanks
Steve in N.J.
11-03-2004 19:19:23
 Re: FMJ Magneto in reply to Jiver, 11-03-2004 10:49:48
Jiv,
The magnetic rotor needs to be pressed out of the lower drive bearing to remove it. Before you do that, you need to remove the snap ring off the bottom of the magnetic rotor shaft. It won't loose it's magnetism. While the rotor shaft is out, they just about all need a new drive bearing. We have all F/M parts in stock if you need any. If you have a rebuilder near you, they can re-magnetize the rotor assy for you. On our rebuilds, I re-magnetize all our rotor assy's. with a magnetizing machine. If you have troubles finding someone local to re-magnetize the rotor assy, we can do it for you. The stronger the magnetic field, the longer & stronger duration of spark will occur.
Steve/B&B Custom Circuits
CMark
12-18-2004 08:20:02
 Re: FMJ Magneto in reply to Steve in N.J., 11-03-2004 19:19:23
I"m looking for an exploded view of a FMJB3 Magneto. I have a new lower cap and gears but I cannot remember the assembly. Any diagrams out there?
Punchie
11-04-2004 18:09:55
Hey Steve
Can you recharge the magnet if they are out of the magneto?
[email protected]
Teddy
Jiver
11-04-2004 10:20:53
Thanks for the advice. I got the shaft out and am going to have it re-magnetized. I found a tractor parts dealer nearby that will send it out.
