WC questions
shaun
11-01-2004 13:46:00
My dad and i are working on our WC tractor.we tore everything off:grill,water pump generator,crank,ect now we are to the point with there are 3 gears. one big gear in the center and 2 other ones on the bottom right and top left. do you guys have any tips for when we take the cam out? the engine is on blocks.but still conected to the tractor. thanks a bunch
shaun
wdTom
11-01-2004 18:06:05
 Re: WC questions in reply to shaun, 11-01-2004 13:46:00
You mayhave to take the oil pump out, remove the oilpan and it will come right out. You need to remove the pushrods and hold the lifters up to get the cam, (carefully) out. the lifters are mushroomed at the bottom and will not come out the top. You may be able to hold them up with clothes pins. If you are going to take the the engine apart much more it would be easier to have it on a bench or engine stand and turn it ukpside down so you could help the cam out by holding it up as you carefully slide it out. Sounds like you should get a reprint of a AC shop manual, not owners manual, although these are usefull too.
old iorn boy
11-02-2004 11:26:06
 Re: WC questions in reply to wdTom, 11-01-2004 18:06:05
You might try tractor supply for the repair manual thats where i got mine. The oil pump does have to come out but it is only two bolts and a tube.
Joe M
11-01-2004 15:37:09
You didn't say you've removed the valve cover, removed the pushrods and taken off the side cover to get the lifters out.
Be very careful removing the cam as to not nick any of the cam bearings with the cam lobes on the way out.
