Starter short/option for fix on WD
jakebah
11-01-2004 07:18:20
I have periodically had a ground/short in the starter arm/button that makes contact with the starter. Each time I pull the box off the internal contacts are making connection with the metal side of the housing. Has anyone came up with an alternative housing or method to engage the starter? Tightening the nut without moving the metal contacts has been a challenge for me. I have converted to a 12 volt system.
Thanks in advance.
tinker
11-02-2004 01:11:56
 Re: Starter short/option for fix on WD in reply to jakebah, 11-01-2004 07:18:20
Originally, there were insulator pieces inside the starter switch. They were triangle shaped and did not allow the hot post to contact the side of the switch. A new one would have them or make them from any thin nonconductive material.
