Side Delivery Rake
Jim Calhoun
10-31-2004 19:29:24
I found what I feel could be a AC side delivery rake. It is PTO driven. The paint looked yellow until I rubbed the oxidation off, then it looked AC orange. It teds as well as rakes and has a lever to switch between the two.
I posted a picture on the help identify page. Any help about this rake would be appreciated!
JMS/MN
10-31-2004 19:42:19
 Re: Side Delivery Rake in reply to Jim Calhoun, 10-31-2004 19:29:24
Sounds like what they made in the late 40s, well into the 50s. Single front and rear wheel, with duals as an option. Front wheel was on a pivot, and would whip at high speed. Rear wheel was fixed. Four bar rake with a gear box to reverse the rotation to ted hay to fluff and dry out existing windrows. Two levers on the hitch to set the left and right side of the basket. Ball hitch on the front, same as the Roto-Baler, combine, silage blower, etc. Even before I could drive tractors it was my job to grease that rake!
John (C-IL)
10-31-2004 19:40:54
third party image
Yep, I've got one just like it. That style of rake was built from 1947 until 1957 when the #7 hay rake was introduced.
Jim Calhoun
10-31-2004 19:51:10
 Re: Side Delivery Rake in reply to John (C-IL), 10-31-2004 19:40:54
Thanks for confirming my suspicions that it is an AC. Now for the questions.... do you know what model? Also I have to repair it as it is missing the PTO shaft. I have a chance to buy it, but am concerned about parts availability and if the rake is a good usable model or is more of a collector piece. If I buy it, I plan to use it.
Thanks
John (C-IL)
11-01-2004 05:29:00
 Re: Side Delivery Rake in reply to Jim Calhoun, 10-31-2004 19:51:10
It's just called a PTO side delivery rake, there isn't a model number that I know of. If you are going to seriously use the rake on more than a few acres you might be better off with a newer model. Figure up what it's going to cost you to get the thing in operable condition and then check out what other rakes will cost you.
JMS/MN
11-01-2004 10:52:46
 Re: Side Delivery Rake in reply to John (C-IL), 11-01-2004 05:29:00
I messed up- took the picture of your rake to be that of JC. Maybe he needs only the pto shaft.
John (C-IL)
11-01-2004 12:17:52
 Re: Side Delivery Rake in reply to JMS/MN, 11-01-2004 10:52:46
No, that is the picture of Jim's rake, I lifted it out of the photo archive.
JMS/MN
10-31-2004 20:00:47
Looks like you need the pto as well as the shield. Check with Larry Swenson in Easton, Mn. at 507-787-2338, or Ron Gould in Milaca, Mn. at 320-983-3500. Another source might be Arnie Hoppe at 218-943-6311.
