54 model D-15 series II (valve lash adj.)
Super Dave
10-31-2004 06:58:58
Just replaced the head on a friends series II she did not have any shop manuals available to reference for the specs. for the valve lash was wondering if there were any way any kind hearted soul could possibly provide me with this info also the torque sequence and ft pds. thanks Dave.
JMS/MN
10-31-2004 10:21:35
 Re: 54 model D-15 series II (valve lash adj.) in reply to Super Dave, 10-31-2004 06:58:58
Sequence for tightening is from the center to the ends, alternating side to side as well. Generally undertorque equally the first time around, then go to final specs. I don't have the lbs or lash for you.
JMS/MN
10-31-2004 16:20:47
 Re: 54 model D-15 series II (valve lash adj.) in reply to JMS/MN, 10-31-2004 10:21:35
Did some checking- knew I had an I&T manual for my D17, but it also includes D15 data. Assume the '54 model was a misprint, since the D-Series came out later- that's ok. Valve lash is this for a non-diesel: Intake, .008-.010. Exhaust is .014-.016. Valves are set hot. Head torque sequence is a bit different from what I said- although I've always followed the same pattern- you crunch it down in the middle and squish the pressure to both ends, alternating from side to side, and do it in two steps. Never lost an engine while following that pattern! Here is what the book says- tighten to 80-85 foot-lbs., retighten to the same after reaching operating temperature. Sequence is this: Draw a picture, with the plugs on the right, #1 bolt is at the center, on the right. 2 is on the left. North is towards the radiator. 3 is first bolt to the SE, 4 is to the NE, 5 is NW, 6 is SW. 7 is further SW, 8 is NW, N of 5. 9 is furthest NE, 10 is furthest SE, 11 is furthest SW, 12 is furthest NW. Or buy the manual for $20.
