WD-45 Serial # Location
Mixman
10-30-2004 17:58:20
Is the serial # on the steel plate over the left brake. I am working on one now and I did not see it.
JMS/MN
10-30-2004 22:52:07
 Re: WD-45 Serial # Location in reply to Mixman, 10-30-2004 17:58:20
Not OVER the left brake, but on the REAR vertical face of the differential housing. Near where the brake spring is hooked onto a hole in the housing. You are in the right neighborhood!
Tony Carbaugh
10-30-2004 18:24:13
Serial number is stamped right below where the brake spring is hooked wd----- -- Tony
pope
11-01-2004 10:09:57
 Re: WD-45 Serial # Location in reply to Tony Carbaugh, 10-30-2004 18:24:13
right infront of the shifter
JMS/MN
11-01-2004 10:47:09
 Re: WD-45 Serial # Location in reply to pope, 11-01-2004 10:09:57
The serial number on a WD is not anywhere near the shift lever.
