B engine timeing
Dan W.
10-30-2004 17:12:55
Stupid question...Which is the #1 cylinder? The one right behind the radiator or the one stamped 1 on the block. This is a '50 B.
Thanks,
Dan
steve(ill)
10-30-2004 17:35:17
 Re: B engine timeing in reply to Dan W., 10-30-2004 17:12:55
the one in front by the radiatoris #1. the timing hole to look at the flywheel is on the left side center of the torque tube, 1 inch hole at flywheel. should be a "F" and "TDC" . static timing is close to the "TDC" then it will move to fire once it is running.
