wd 45 hydraulic fluid level
neil berglund
10-29-2004 23:03:23
My tractor does not have a dipstick for hydraulic fluid level since a return line was tee'd into the case. How can I check proper level. How far below case (inches) is correct fluid level.
punchie
10-31-2004 03:47:52
 Re: wd 45 hydraulic fluid level in reply to neil berglund, 10-29-2004 23:03:23
HI Neil
I was hoping someone knew off hand , but knowone has gotting back to you. I'm guessing anout 1 inch, I don't think the hole dipstick is more than about 2" long. We just put it in as needed.
Teddy
P.S. Any good clean oil will work, use 30 wt. in summer, and thiner in the winter.
punchie
11-04-2004 18:10:00
 Re: wd 45 hydraulic fluid level in reply to punchie, 10-31-2004 03:47:52
Neil
About 1.5 from top of dipstick.
Teddy
