WD/WC Front Hubs
need help
10-28-2004 19:57:04
I am in the process of trying to remove the hubs of my tractors. Are the hub cabs threaded on or pressed on? If threaded on are they right hand or left hand threaded? Also whats the easiest way to remove them? Thanks
John (C-IL)
10-29-2004 05:40:39
 Re: WD/WC Front Hubs in reply to need help, 10-28-2004 19:57:04
Also, spray some of your favorite penetrant around the cap and lightly tap all around it with a hammer. I've always used a pipe wrench. If they are rusted, never been off and don't come off easily you may need to lightly heat them. Be very careful with the torch as the caps aren't very thick.
JMS/MN
10-28-2004 21:40:15
Threaded on, right hand threads. Use a pipe wrench on them, if you don't have the right size socket. We never did back home, just used a pipe wrench. Nobody had much for tools in those days!
