wiring diagram for C
Cleveland
10-28-2004 19:39:56
Can anyone email me a wiring diagram for a 1941 C? It"s a 6 volt system with a coil, not magneto. Thanks
Denver
02-02-2005 11:33:09
 Re: wiring diagram for C in reply to Cleveland, 10-28-2004 19:39:56
I am in need of a wiring diagram for an Allis Chalmers C, 1946 model with 6 volt coil no magneto.
Thank you.
steve(ill)
10-28-2004 20:22:47
i can supply you a diagram. main part is the charging circuit including the generator and light switch. do you have generator still? the distributor is not standard on the C, it was a mag, but all you need is power to the coil to make it work, easy modification. [email protected]
Cleveland
10-29-2004 20:19:36
 Re: wiring diagram for C in reply to steve(ill), 10-28-2004 20:22:47
The generator is still there. The diagram would be a great help, thank you! [email protected]
Has to be electric start!
10-28-2004 19:55:43
I thought that year was hand crank start with Mag.
Could be wrong
Dick L
10-29-2004 08:03:28
 Re: wiring diagram for C in reply to Has to be electric start!, 10-28-2004 19:55:43
The only real difference in the wiring between the magneto is that rather than ground the shutoff switch to the tractor frame is that you put the ground wire on the nutral side of the battery. The wire that hooks to the magneto goes on the coil. Then a wire runs from the coil to the points. per drawing.
