power steering on JD 3010
Henk
10-28-2004 04:28:49
The JD 3010 steering only works to the left and the problem is not in the front since I switched the lines and at that time it didn't steer to the left. but somewhere in the steering colum do you know how to fix it?
jdemaris
10-28-2004 05:44:01
 Re: power steering on JD 3010 in reply to Henk, 10-28-2004 04:28:49
You've probably got a steering control valve problem. The valve has two rocker arms that each control two hydraulic valves (one pressure and one return) - i.e. two rocker arms and four valves. One rocker is for left turns and one rocker is for right turns. So, from what you say, it's likely that is where the problem is. All the individual parts are available and the rocker arms are adjustable.
