wd45 implements
mgr
10-27-2004 20:01:29
what is the biggest pull type mower and disk I should use with a good running wd45?
BushogPapa
10-29-2004 18:14:46
 Re: wd45 implements in reply to mgr, 10-27-2004 20:01:29
I put duals on my WD-45, and can pull my IH No 37 disc and harrow anywhere in 3rd gear.. That No 37 is 10 ft or a little more.. It takes about 45 minutes to put them on once you know how much block to run the rar tires up on..!! If you use a Bush Hog..be SURE the slip-clutch is able to slip to protect the PTO from shock..!!
Sid
10-27-2004 21:43:33
I have pulled ninefoot haybines, 7 foot rotary mower to clip pasture and cut light brush and thick grass and weeds. Eight foot tandem disc. I pull a ten foot disc with my 170 and a WD45 would pull it in some conditios but not where i use it.
mgr
10-28-2004 04:48:56
 Re: wd45 implements in reply to Sid , 10-27-2004 21:43:33
Thanks! Now all I have to do is find a 7' mower and a disk. Any ideas?
RickL
10-28-2004 06:37:36
 Re: wd45 implements in reply to mgr, 10-28-2004 04:48:56
I have a front mount cultivator for the WD45 and also a belt pulley attachment if that would help you out any.
