B 10 CARBURETOR
JOHN HELMS
10-27-2004 18:24:45
I HAVE A B10 THAT I CANNOT GET THE CARBURETOR TO STOP FLOODING. ANY SUGESTIONS. OR ANYONE KNOW WHERE I CAN BUY ONE. THANKS FOR ANY HELP.
Pat Cruise
10-29-2004 18:28:25
 Re: B 10 CARBURETOR in reply to JOHN HELMS, 10-27-2004 18:24:45
John Does your B-10 have the Briggs and Stratton engine on it?If so what it is probably doing is the needle inthe carb.on the float probably has a wear ring wore into the tip from vibration.Briggs engines are notorious for this.A carb. kit from any engine dealer would fix the problem.Also take the float out and shake it to see if any gas has gotten inside it.These can freeze during cold temps and cause them to crack causing a leak also.Good Luck!
