D 14 Smokes Intermittently
Terry Neudorf
10-25-2004 10:14:19
I"ve just purchased a 1958 D14. When it warms up it smokes, but not all the time, may smoke for a bit then quit then smoke some more. It really doesn"t change. It had 15-40 oil when I bought it, I put in 10-30 for winter. Is this too thin and causing the smoking problem. Otherwise the engine starts,sounds and runs great.
Also when I lift the 3 pt. hitch the pump makes a knocking noise. The blade I have on is pretty heavy. Is this causing the problem or am I on borrowed time.
Thanks
old
10-25-2004 10:45:19
 Re: D 14 Smokes Intermittently in reply to Terry Neudorf, 10-25-2004 10:14:19
You may have a valve sticking off and on makeing it smoke, or maybe a ring sticking off and on. I wouldn't worry about it. Also I have found running a mlti weight oil can also cause that type of problem. I run a stright weight oil in all my old tractors and have never had oil type problems with any of them. As far as the lift problem I can't say for sure but my D-17 makes a little noise when I use the hydralic but it sounds like a normal noise.
