WD horsepower?
Sr.
10-22-2004 10:17:31
I just bought a WD and I do not know the HP. Does the WD have enough HP to lift a round bale with a loader bale spear?
gene
10-22-2004 22:10:49
 Re: WD horsepower? in reply to Sr., 10-22-2004 10:17:31
I used the WD this summer to haul 522 concret retaining wall blocks, 72 lbs each, on one of the universial carriers attached to a 3-point. The back end of the universal carrier extends approximately 3 feet beyond the rear tires. 10 blocks were all we could haul and barely steer (keep the front end on the ground). 12 blocks not steering.
Hope this helps.
Gene
gene
10-22-2004 22:17:26
 Re: WD horsepower? in reply to gene, 10-22-2004 22:10:49
I should add. Fluid in rear tires. No weights on the front end. We, my son and I, use a couple of WDs for general purpose construction and farm type work. Plenty of horse power - they are a little light on the front end with out additional weights.
Screamin DC
10-22-2004 14:52:39
Depending on what size bale you wanna pick up, you might run into weight problems as well as hp. A 5x5 1200 lb bale would be more than enough to pick the back end off the ground. A stout WD should be every bit of 35 hp.
Punchie
10-22-2004 15:17:02
 Re: WD horsepower? in reply to Screamin DC, 10-22-2004 14:52:39
I have and wd 13.6 X 28 with water (loaded) . It has a front manure scoop on it . As I tell people it will left a ton. 1000 pounds no trouble at all, it will lift that at an idle. Now about moving around ?? My is a NF so better be on the level side, I would think lifting from the front 1200-1500 would not be a problem but from the back I bet the front would come up at around 500-750. Be casefull I read allot about a few people getting killed moving the bales around.
Punchie
