help with a coolent leak
Larry in wiscon
10-21-2004 09:05:16
When installing the new intake gaskets on my wd, I chased the threads with a tap. After doing this coolent started leaking from the rear bolt hole. I installed that bolt with teflon tape. Has anyone else had this happen? Thanks in advance.
Dick L
10-21-2004 10:53:55
 Re: help with a coolent leak in reply to Larry in wisconsin, 10-21-2004 09:05:16
What was said below. Teflon tape really only works well on tapered threads. On a streight thread it just pushes up the threads. I also put a small dab of the silicon sealant in around the hole as well as on the threads. I said small dab.
gene
10-21-2004 10:16:58
Yup. Happened to me. As Old states, use a thread sealent.
old
10-21-2004 09:35:30
I haven't had it happen to me but I know how to fix the problem. Remove the bolt, clean it off and then cover the treads with silcone seal and reinstall.
