WD-45 hydraulics
john W
06-06-1999 16:33:42
I want to run the tractor hydraulics through a two-way selector valve so I can selectively operate the bucket and a 3-pt. Question is, which oil port on the pump would be best to use, one of the two front ports, or the rear port? I guess I will use the control in the "hold" mode.
Ron
06-14-1999 21:02:03
 Re: WD-45 hydraulics in reply to john W, 06-06-1999 16:33:42
On mine I disconnected the two front lines from the rear lift cylinders at the pump ports, plugged one port and connected a 2 spool valve on the other. One for the loader (or remote cylinder) and connected the rear lift to the other. It gives much more civilized control for both and you can also plumb in a filter on the return line. The return line was teed into the filler port on the hydraulic reservoir. If you have questions e-mail me directly.
