Draw bar on a '39B
Chris (OR)
10-20-2004 13:22:02
So I have a rebuilt '39B that I use mostly for mowing.... I was thinking about digging some bushes out... I got the tractor instead and a rope and pulled them out via the drawbar. My question is there supposed to be some connecting rods between the drawbar and seat frame? I have seen photos with and with out them.... I think it would make it stronger... Anyone have a set???
Thanks
Chris Horn
Scappoose Oregon...
Dick L
10-22-2004 06:28:33
 Try This Drawing in reply to Chris (OR), 10-20-2004 13:22:02
I took this from my manual and it should come up at the link.
Dick L
10-22-2004 12:54:14
 I just looked at the Pic better in reply to Dick L, 10-22-2004 06:28:33
And that is a C drawbar but still was special equipment for both B"s and C"s.
Tom Davison
10-20-2004 16:17:35
 Re: Draw bar on a '39B in reply to Chris (OR), 10-20-2004 13:22:02
The braces that you have seen were provided with the BC Mower. They were used to stabilize the drawbar so the mower belt tension would not vary by weight placed on the drawbar, or under a hard pull. I have two B's and a C. I do not find it necessary to use the braces except when the mower is mounted.
Stan(PA)
10-20-2004 16:08:17
Mine has threaded rod. Don"t know what was originally used, but the threaded rod works good, and it"s easy to get..... ..Stan
