Shifting problems!!!
Tyler Duncombe
10-18-2004 18:02:11
We have a 1952 Aliis Chalmers CA when we fist bought the tractor one could pull the shifter from the trans. We since fixed it hadent any problems with it utill last tues. I was backing up and went to shift in first and it jumped out of the fork and had to tear it down and realine them. I was completely stopped when i made the change. Also does anyone know the weight of gear lube used in the trans?
steve(ill)
10-20-2004 18:45:16
 Re: Shifting problems!!! in reply to Tyler Duncombe, 10-18-2004 18:02:11
if it goes into two gears at a time, or cant go into a gear in means the shift forks or pins are worn. need to pull the side cover and inspect the forks and link.---- the transmission, bevel gear and pto housing all share the same oil. you fill at trans left side by your foot. takes about 8-9- quarts. Most people use hytrans or similar 20 wt hydraulic- transmission fluid. Gears could use something heavier, but the hydraulic system needs the thinner oil. Hytrans will keep it from foaming and collecting water. Buy universal hytrans at Wal Mart or Farm Store.
