WC serial number help!
shaun
10-18-2004 16:25:04
hey everyone. i need help trying to find the serial number. i know that its on the back "pumpkin" but i cant make out the numbers. they are kind of smeard.is there another place were the number is stamped on the tractor? if so then please tell me about it. i can only make out 2 numbers on the rear were the serial number is suposivly stamped. there 69. your help is appreciated thanks!
gene
10-21-2004 10:33:49
 Re: WC serial number help! in reply to shaun, 10-18-2004 16:25:04
Went and check the serial number location indicated by WD Tom. Sure enough there is an engine serial number stamped just above the bell housing. The engine is from a 37 WC. The engine serial number is about 1,000 below the number stamped in the differential.
JMS/MN
10-19-2004 13:22:19
If what Gene said does not work, try paint remover. Do not get real aggressive with sanding, etc. The numbers are STAMPED in, not cast. Over time, the tractor may have been repainted once or twice and the numbers are not easy to read.
gene
10-19-2004 09:03:09
Take a wire brush to the serial numbers. That should bring them out. The numbers get filled up with crud. Still not readable. Clean up the area real good. Spray paint, let dry. Then sand lightly the machined area. This should bring out the numbers.
The only place that I know of for tractor serial numbers on the WC is the center of the differential. Engine numbers are supposed to be just to the right of the carburator. However I have two WC blocks with no serial numbers.
wdTom
10-20-2004 18:02:58
 Re: WC serial number help! in reply to gene, 10-19-2004 09:03:09
Early WCs had the engine serial no. on the back of the block above the bellhousing, on a horizontal surface I think. Check yours. They could be replacement blocks too maybe?
