too much compression?
barry macdougal
10-17-2004 13:30:36
when i let my wd sit for a few days in order to get it to start i have to pull the no.4 plug out then she starts right up. as long as i run it everyday it's fine.what's causing this?
Sid
10-17-2004 17:49:39
 Re: too much compression? in reply to barry macdougall, 10-17-2004 13:30:36
For what it is worth I agree with gene. I also would do a tune up while I was at it.
gene
10-17-2004 15:20:39
Weak battery, weak starter, corrosion on battery terminals-connectioms.
Jon H
10-19-2004 10:34:56
 Re: too much compression? in reply to gene, 10-17-2004 15:20:39
Does the engine refuse to turn over unless you remove the #4 plug,or just turn too slow to start?. If it does not turn over unless you remove the #4 plug,you may have a slow coolant leak into #4 cylinder causing a hydraulic lock. Does any liquid come out of the plug hole when you start it with #4 removed?
